October 31, 2024, 11:42:12 pm
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: Foamy prestone « previous next »
Author Topic: Foamy prestone  (Read 1717 times)
« on: July 11, 2006, 05:50:31 pm »
Got this piece of crap 2.8 back in and running unfortunately it over heats with a thermostat in so I figured air lock and removed thermostat and ran for a while, took for a few short drives then let cool to instal a t-stat. well took off the cap and foam spewed out now that doesn't look very good I am thinking head gasket or some thing any ideas nicer than that to deal with. Dan
« Reply #1 on: July 12, 2006, 08:14:56 am »
Any "chocolate milk" in the bottom of the oil pan and/or coolant being pushed past the radiator cap prematurely?
« Reply #2 on: July 12, 2006, 10:09:20 am »
Oil is fine and pan is clean and its not losing prestone its just getting foamy and will over heat with a t-stat installed. Dan
« Reply #3 on: July 12, 2006, 10:53:41 am »
Have you drilled the 'stat?  I always put a couple of small holes in to allow any air to travel thru the system.  Can you see the water moving in the rad?  I wonder if the w/pump is just spinning enough to froth the coolant and not to circulate it properly.
« Reply #4 on: July 12, 2006, 11:54:51 am »
That was my next thought.  Slipping impeller or other pumping problem which can barely move coolant with the t-stat removed, and can't do squat with the t-stat in place.
Dan is this the same car you just did the timing chain on?
« Reply #5 on: July 12, 2006, 06:36:08 pm »
Yep same car looks like this one hasn't seen regular maintenance for a long time. Dan
