December 28, 2024, 05:44:24 pm
Ottawa Fiero Club Forum  |  Buy/Sell/Trade  |  Parts  |  Topic: FS: Near-OEM 14" alloy rims + tires « previous next »
Author Topic: FS: Near-OEM 14" alloy rims + tires  (Read 1689 times)
« on: October 14, 2006, 08:32:03 am »
Likely from a Sunbird from the same era as the Fiero, we have four alloy rims (including tires) which we no longer need:
  • 14" diameter;
  • 6" wide;
  • +42mm offset (approximate);
  • 5x100mm bolt circle.
The rims have been stripped, media-blasted, and freshly clear coated.
They fit the front of any pre-88 Fiero just fine.  Depending upon the type of balancing weights used and the brand of struts installed, they seem to fit the rear of some pre-88s but not others.  Installing a 5mm spacer between the hub and the rim takes care of any clearance problems.
The tires are Pacemark Radial G/T.  One pair of 205/60R14 with ~4mm tread depth, one pair of 215/60R14 with ~5mm tread depth.
$25 per pair.
« Last Edit: October 14, 2006, 08:48:47 am by dguy » Logged
« Reply #1 on: October 16, 2006, 09:14:45 pm »
Sold.
