November 01, 2024, 04:26:38 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: seals in rubber « previous next »
Author Topic: seals in rubber  (Read 1562 times)
Rebel
« on: January 02, 2003, 10:48:54 pm »
Protecting Door, Front Lid, Trunk and Especially Sunroof and T-Top Seals
Required Items:
Simple Green (has no harsh chemicals)
Small brush (an old toothbrush will work fine)
lots of rags
bucket of water
Castor Oil
Begin by cleaning the seal you want to protect with Simple Green.
Dip the brush into your bucket of water and lightly scrub the seal to get dirt out of the pores.
Wipe the seal dry and let it set for about an hour to air dry.
Pour some Castor Oil onto a clean rag and rub it into the seal.
The seal will not absorb it all right away so leaving a little 'shine' is okay.
Castor Oil will soak into the seal, keep it soft and pliant and, make it swell slightly.
If you've had a wind 'whistle' or leak, it will probably stop after this application.
I repeat this on my car about three times per year.
That's it !
Note: Castor Oil will stain your clothes, permanently. It will leave a mark on your side windows, temporarily.
You can clean your windows after about a week.
If it protects F-4 canopy seals at Mach 1.2 @ 40,000 feet, I figured it would work on a Fiero.
It's worked on my cars for the last 30 years.
You've spent about $3 and 2 hours. Your seals are like new and that annoying whistle/leak is gone !
Rebel
« Reply #1 on: January 02, 2003, 10:50:35 pm »
I t works very well worth the efford
Madscanner
WWW
« Reply #2 on: November 04, 2005, 04:01:58 pm »
Hi All
Just tried a Google search on "Simple Green" but got nothing meaningful.
What is the product (bearing in mind that there might be something similiar, or the same under a different name, here in the UK?
The Madscanner
'88 Formula
'85 SE 2M6
'93 Eunos Roadster
'01 Fiesta Zetec S (for when I need more than 2 seats!)
'06 Vauxhall Astra (for when the Fiesta gets sold)
'01 Yamaha Dragstar
« Reply #3 on: November 05, 2005, 01:21:15 pm »
Simple Green is not much more than a mild (mostly organic I think) detergent.  I've most often seen it packaged as detergent-impregnated light duty scrubbing pads, slightly more abrasive than a sponge.
A mild dish soap & textured cloth (such as your spouse's favorite bath towell) should work just as well if you can't find an equivalent over there.  You want to use a cleaner which will help lift off dirt, but without drying out or otherwise damaging the rubber.
Madscanner
WWW
« Reply #4 on: November 08, 2005, 05:58:03 am »
Ok - Thanks.
Paul aka The Madscanner
'85 SE 2M6
'88 Formula
'85 SE 2M6
'93 Eunos Roadster
'01 Yamaha Dragstar
