December 27, 2024, 06:57:21 am
Ottawa Fiero Club Forum  |  Buy/Sell/Trade  |  Sell your Car  |  Topic: G6 6 speed low low price...see inside...pic's « previous next »
Author Topic: G6 6 speed low low price...see inside...pic's  (Read 2509 times)
Joe Fieroshop
« on: November 20, 2006, 05:39:00 pm »
I'm given the opportunaty to purchase brand new in the box G6 6 speed tranny's. for a very low price of $1000.00 CDN. plush accual shipping, they also come with the factory slave bearing, the catch is I have to purchase 10 tranny's for this group buy.
please let me know if anyone is interested.
Thanks
Joe
« Reply #1 on: November 20, 2006, 07:40:32 pm »
Definitely interested, but your timing stinks.  We're about 10 days away from closing a deal on a house.  i.e.  no can do.   Sad
« Reply #2 on: November 20, 2006, 07:48:50 pm »
Two questions one do they bolt up to our bellhousing ok and two is the final drive going to give an over all lower rpm in top gear than the Getrag 5 speed or is it just one more shift on the way there. Dan
Joe Fieroshop
« Reply #3 on: November 21, 2006, 04:29:07 pm »
I'm trying to find this information so I can answer all your question's. I'll keep you posted.
Thanks
Joe
« Reply #4 on: November 22, 2006, 08:30:52 am »
As far as I know the G6 tranny's bolt pattern is identical.
One would need a custom clutch solution however, as the input shaft diameter/spline count doesn't match that of a Fiero clutch.  Not to mention that the F40 is normally matched to a thicker-than-what-we're-used-to dual-mass flywheel; the position and end-to-end travel of the release bearing may require a spacer behind the flywheel or a flywheel with a raised hat on the back of it to push the pressure plate further "in" to the bellhousing.
The bookmark I originally had has gone bad Sad, but look for Aaron's second post here.
First gear would probably be spin city if coupled to something with a respectable amount of low-rpm torque, however 2 through 6 are nicely useable.  Not to mention that its claim to hold close to 300 ft-lbs is just a touch friendlier than 20 year old trannys which were intended for use with significantly weaker engines.
« Reply #5 on: November 24, 2006, 07:23:42 pm »
Did some checking while the 6 speed is stronger than the Getrag 5 speed it is basically one extra shift for a measly 100 rpm drop in in top gear. I think I will stay with my getrag at $150 apiece for fwd ones from wreckers I will have to break quite a few to reach $1,000 let alone the extra costs for fancy flywheels and such. Dan
Joe Fieroshop
« Reply #6 on: November 28, 2006, 11:39:32 am »
No problem guy's I tried to help out.
Thanks
Joe
