April 05, 2025, 01:56:41 am
Ottawa Fiero Club Forum  |  Off Topic  |  Other  |  Topic: Dry weather nosebleeds « previous next »
Author Topic: Dry weather nosebleeds  (Read 2732 times)
« on: January 29, 2007, 09:02:26 am »
Anyone happen to have an "at home" cure for this crap?  I'm really getting tired of either not blowing my nose, or walking around with a tissue jammed up it.   Angry
...if the answer is no, I'll be looking for three volunteers on Saturday.  Two to hold me down, while the third jams a hot soldering iron up my nose and turns everything up there in to scar tissue!
« Reply #1 on: January 29, 2007, 12:33:19 pm »
Don;
You need a humidifier and a relative humidity indicator.  I use the digital ones from the pet store because they are cheep (about $25) and accurate (unlike the analog ones).  You want to keep the humidity between 45 and 50%.  If you don’t have a humidifier you can just boil a large pot of water on the stove.
« Reply #2 on: January 29, 2007, 12:58:59 pm »
I wish it was that simple--we have three fish tanks in the house, ranging from 30-something gallons up to about 85 gal.  Keeping the humidity level up in the house is not a problem.  Smiley
« Reply #3 on: January 29, 2007, 04:15:09 pm »
Are you sure?  Open watter isn't usually enough to do it in the winter time.
« Reply #4 on: January 29, 2007, 04:52:39 pm »
What about a nasal mist from the drug store?
« Reply #5 on: January 29, 2007, 07:08:55 pm »
Yep, 'fraid so.  The basement is a bit drier due to the pellet stove, but the main level where all the fish are is at about 45-50% right now.  At least that's what the digi hygrometer on our dehumidifier says (no we're not running it--just used it a few minutes ago to check the humidity).
D'oh.  I never even thought to look for a nasal moisturizer.  The only nasal mist I've ever encountered were decongestants, and allergy meds when I was a kid.  Thanks.
I've thought about snorting hand lotion once or twice out of frustration, but (thankfully?) never actually tried it.   Grin
« Reply #6 on: January 29, 2007, 08:14:36 pm »
I was given a nasal mist when I had some surgery on my nose.  There is also a nasal vasseline that you can get, but I bet you it costs more than the regular vasseline because of the little tube.
« Reply #7 on: January 30, 2007, 09:40:28 am »
Two other things you can try:
1) try not to blow your nose too often when at work
2) bring that humidifier to work and plug it in right at your desk
3) okay there  might be a third, breath through your mouth when outside or at work
« Reply #8 on: January 30, 2007, 11:46:36 am »
BTW - The nasal gel I have is called Rhinaris and it came in a 5g tube.
« Reply #9 on: February 03, 2007, 01:55:40 pm »
I have had nose bleeds all my life. I my nostrils koterized, a little painful but worth it. Still have the odd nose bleed but alot less. The doctor also suggested Vasseline, It didn't help much. But mine was a more serious case.
