April 19, 2025, 08:52:51 am
Ottawa Fiero Club Forum  |  General  |  Mods  |  Topic: Taillight Apearance Opinions Wanted « previous next »
Poll
Question: Which set up is more pleasing to the eye?
Brake.....Running+brake......turn signal (picture 1)   -9 (90%)
Brake.... Turn Signal.......running+brake (picture 2)   -1 (10%)
Total Voters: 8
Author Topic: Taillight Apearance Opinions Wanted  (Read 9814 times)
« on: February 20, 2007, 06:30:57 pm »
Changing the guts of the coupe taillights a little bit.  Which set up is more pleasing to the eye?
Gizmo
« Reply #1 on: February 20, 2007, 07:23:01 pm »
I think this is some form of blotch test.
« Reply #2 on: February 20, 2007, 09:25:02 pm »
Its a moot point Gary, your car doesn't go anywhere.
« Reply #3 on: February 20, 2007, 09:42:24 pm »
Your collective cruelty knows no bounds.....
Which of these is more awe inspiring on a non-moving sort of car shaped thingie.
Gizmo
« Reply #4 on: February 20, 2007, 10:25:56 pm »
Lets have a poll!
« Reply #5 on: February 21, 2007, 06:51:13 am »
I like the mustard stain on the far outside better.
« Reply #6 on: February 21, 2007, 09:31:36 am »
After staring at it for a while it really does seem to be the obvious choice.
« Reply #7 on: February 21, 2007, 11:44:29 am »
Anyone bother to check the law?
There is a reason most cars have lights that wrap around the corner.  One bulb two directions, and it's cheeper to do that way.
However, being an older car I don't think we are bounded by that law, but think about it anyway.  The easyer it is to see that blinking light the fewer....
« Reply #8 on: February 21, 2007, 11:46:29 am »
Alternately you could add a mid point turn signal and then I don't think it matters.
« Reply #9 on: February 21, 2007, 04:48:13 pm »
I have side marker lights.
If my car is on such an angle that you are not able to see a rear signal light then my car is:
a) doing a 360 spin
b) already performing a turn
c) about to be t-boned by your car.
Mid point turn signals are nice on a 60 foot Highway tractor, but a bit of bling on a 14 foot car.
MacPhail
« Reply #10 on: February 21, 2007, 05:28:36 pm »
Mmmmmmmmmm.....BLING!  Me likes BLING!   Cheesy
« Reply #11 on: February 21, 2007, 06:46:07 pm »
Bling eh?  I think more usefull for blind spot drivers.
For all vehicles over 30 feet an additional midpoint turn signal is required. (ie. trailer)
« Reply #12 on: February 21, 2007, 07:27:27 pm »
I believe that's what I said.  If you are in a position coming up on a VW Golf where you cannot see the tail but can see the side flasher I suspect you are beside the driver.  If he turns toward you then you're screwed.
This is a Fiero we have here, not a tanker truck.  Short of a roof lightbar, regular lighting should be okay.
cowans
I'm a llama!
« Reply #13 on: February 22, 2007, 09:11:47 am »
[This is a Fiero we have here, not a tanker truck.  [/quote]
Corrected for clarity.... "This is MY PARKED Fiero we have here, not a tanker truck"
so that the taillight issue is moot! It's still hasn't moved! heheh!
 Cheesy Cheesy Cheesy
I'd go with the mustard lens on thwe outside as well!
MacPhail
« Reply #14 on: February 22, 2007, 12:57:49 pm »
Gary, will the back-up lights be mayonnaise coloured to go along with the musturd and ketchup ones?   Azn
