November 01, 2024, 11:30:04 pm
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: New forum section coming « previous next »
Poll
Question: Where should the new section be displayed?
General (where everyone, even guests can read it)
Members-only (invisible unless logged in, just like Events)
None of the above (please describe below)
Author Topic: New forum section coming  (Read 1832 times)
« on: February 28, 2007, 09:18:21 am »
Hey folks...
Working on a new section; basically a place where new & old members alike can introduce themselves, babble about their cars, their hobbies, etc.  It's more or less the product of some thought about how well most of the "regulars" know each other, and how the familiar banter may unintentionally make newcomers feel left out.
I'll make the section active once I've finished writing up a set of guidelines and whatnot...   Lips Sealed
In the mean time, please give some thought to which area of the forum would be most appropriate for this sort of thing, and cast your vote above.  The first two choices should be self-explanatory; please don't select "None of the above" unless you intend to post a suggestion of your own.   Smiley
Thanks.
« Reply #1 on: February 28, 2007, 09:52:57 am »
I think it would go well under "Off Topic" and have a section called "New Member Introductions".
Kitten
« Reply #2 on: February 28, 2007, 01:20:23 pm »
Personally I would put it in the members only section...
« Reply #3 on: February 28, 2007, 07:45:37 pm »
^  ^  Arrr! Me too.
lacelles
WWW
« Reply #4 on: February 28, 2007, 08:09:03 pm »
Members-only  Afro
http://www.lacelle.ca
« Reply #5 on: February 28, 2007, 09:08:11 pm »
Question:  What is the advantage to having it under Members Only?  Anyone can sign up and become a member...heck, you guys let Frenchie join!   Evil
hehe
Sorry Stephane...had to even out the make-fun-of-ratio as Gary has been a target quite a bit as of late.  Wink
But seriously.  How 'bout a new rule where you have to post submit an intro about your self before gettting access to the members-only section to keep out the riff-raff?  Not you Gary...don't you worry!   Cheesy
« Reply #6 on: March 01, 2007, 05:38:39 am »
Should post an intro before getting 'posting' access to any of the board.
« Reply #7 on: March 01, 2007, 12:23:07 pm »
The goal?
If it’s to not scare newcomers off then it should be hidden.
If it’s to encourage people to chat then it should not be hidden (sometimes people join for that reason).
We already have general and off topic areas, so you would have to create another.  Let me think a few minutes.....
I have thought about it and I think you may just end up confusing new members as to where to post.  So retract my vote for members only.
« Reply #8 on: March 01, 2007, 01:58:47 pm »
Either suggestion is do-able, if I tweak the board permissions a bit and make a small change to the post count groups.
Whether or not there is any real benefit to forcing people to bare their souls is a question in and of itself however.  I can understand it if you're not a fan of hit-and-run use of the classifieds.  What other benefits would there be however, if any?   Huh
(in other words, convince me that such restrictions would be overall a good thing and that a significant number of people would be happy with the changes, and I'll do it)
« Last Edit: March 01, 2007, 02:10:19 pm by dguy » Logged
« Reply #9 on: March 03, 2007, 07:50:56 am »
New section to appear shortly after this reply...  currently with no "you must post an intro before..." -type restrictions.  i.e. Use of it is encouraged, but not required.
I'm still open to be convinced that essentially forcing someone to write a bio is preferred, in case anyone wants to bend my ears a bit.  Smiley
