April 19, 2025, 08:26:20 am
Push Button Start?
Topic: Push Button Start? (Read 4557 times)
MacPhail
Push Button Start?
March 14, 2007, 12:19:33 am »
On
eBay
Are these things reliable?
fixed funky url code that resulted in a busted link
Last Edit: March 14, 2007, 01:46:19 pm by dguy
Re: Push Button Start?
March 14, 2007, 01:49:27 pm »
So long as the switch's contacts can reliably handle the current of the starter solenoid, I don't see why they wouldn't be (reliable).
I once installed a homemade starter push-button in a friend's Daytona for much less.
March 14, 2007, 03:53:21 pm »
It's only good for the bling factor. Plus it adds weight!
March 14, 2007, 04:36:17 pm »
Quote from: aaron88 on March 14, 2007, 03:53:21 pm
Yes, but it's Derek....... Derek Bling!
MacPhail
March 14, 2007, 05:44:25 pm »
Hey, the best way to cut down on weight is for me to go on a diet.
A push button start ain't going to make much a difference if I have a donut every morning for breakfast. lol
Gizmo
March 14, 2007, 06:11:22 pm »
Could pickup a momentary button at Princess for a fraction of that price!
cowans
I'm a llama!
March 15, 2007, 08:47:15 am »
Quote from: dguy on March 14, 2007, 01:49:27 pm
Use a high amp Relay.... that way the switch's contact just needs to power up the relay.... very little current required! Some of the best/nicer (and most expensive) buttons come from Honda S2000. You can find some cheeper units that start Generacs, etc!
Last Edit: March 15, 2007, 08:51:44 am by cowans
March 16, 2007, 09:37:05 am »
You should have a hidden button at the back (or a remote start). Then make a fake hole for a crank.
Walk to back ***Insert crank****Turn rapidly several times*** push the hidden button and the engine starts.
That would freak them out.........................But it isn't JDM
MacPhail
March 16, 2007, 01:44:03 pm »
If it's not JDM, it's not going in Il Fiasco.
But one of those Business Depot/Staples "Easy Buttons" that they use in their advertising MIGHT look pretty cool.
March 17, 2007, 10:24:52 am »
Last time I installed a seperate start button on a car I used a stock clutch start switch and made a bracket up for it to mount on the brake pedal. So the brake had to be applied for the starter to engage, still had to turn the ignition switch for the actual starter to work but it would not start with out the brake pedal depresses. This switch could also be mounted else where fairly easily with just about any thing you want covering it so when you push the button over the switch the car starts. Dan
Push Button Start?
