January 10, 2025, 06:42:22 pm
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: shifter too long « previous next »
Author Topic: shifter too long  (Read 1315 times)
juggalojesus87
« on: April 18, 2007, 06:32:23 am »
anyone ever think about just cutting the stock shifter down and putting a aftermarket knob on top? i hate how long the shifter is and cant afford a new one right now Undecided
« Reply #1 on: April 18, 2007, 07:57:07 am »
Yup.  Some people even do it instead of just thinking about it.  Wink
You can also hunt down the shifter from a 84--they're certainly not stubby, but they're a drop-in which is shorter than the shifters from the other model years.
« Reply #2 on: April 18, 2007, 09:33:47 am »
While it is not a true 'short' shifter, cutting the shaft does give a slightly shorter throw and is more comfortable (to me anyway).  With the cables etc, the shift will always be a bit vague compared to having the shifter sprout from the tranny as in a front engine rwd.
Grind the shaft from the bottom shifter piece and weld on a new shaft.  Either a cut Fiero one or from any car.  The Fiero shaft is so thick that few knobs fit right on.  You can use a slimmer shaft from an imprt and just spin on an aftermarket knob.
I'll put up some pics of the process later.
« Reply #3 on: April 18, 2007, 11:47:14 am »
I have done a few 84's all I do is cut off the shaft where I want to and weld a bolt to it that will thread into the new shifter knob. Dan
