April 26, 2025, 03:02:23 pm
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: Is it normal? « previous next »
Author Topic: Is it normal?  (Read 2422 times)
« on: May 16, 2007, 07:18:33 am »
When I start my car the wipers make one sweep across the windshield. Is that normal?
« Reply #1 on: May 16, 2007, 08:22:25 am »
For some people, yes.   Wink
Most common causes are failed capacitors in the wiper delay module, or a bad switch in the column.
« Reply #2 on: May 16, 2007, 10:42:16 am »
  Ah, the phantom wipe. My first Fiero did that every so often.   Kevin
« Reply #3 on: May 16, 2007, 03:00:31 pm »
Assuming it's not you don't do it.
« Reply #4 on: May 16, 2007, 06:21:46 pm »
The phantom wipe! I like that. I'll just tell people it's a rare option   Afro
