April 26, 2025, 08:25:28 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: Door Removal? « previous next »
Author Topic: Door Removal?  (Read 2314 times)
« on: August 19, 2007, 05:16:00 pm »
Where is the best place to unhook the electrics when removing the doors? In the door or in the chassis? I'm swapping doors, thought I'd ask before I take the door panel off.
« Reply #1 on: August 19, 2007, 05:25:08 pm »
Unless you have the arms of a capuchin monkey and the fingers of a 8 year old, in the chassis.
If you remove the interior kick panel, you'll find one or two plugs hidden behind it.  Separate those, and feed the door side harness(es) back through the chassis and out in to the door jamb.
While you're in there, you might as well undo the one hinge bolt which is threaded in from the inside.  The other three are threaded in from the outside.   Roll Eyes
« Reply #2 on: August 19, 2007, 08:53:11 pm »
Cool, thanks as always for the help.
