January 11, 2025, 01:50:17 pm
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: 2.8 problem « previous next »
Author Topic: 2.8 problem  (Read 2977 times)
lsixtyseven
« on: August 24, 2007, 07:12:21 pm »
My 2.8 won't rev above 4000 rpm under load, but will in neutral, anyone have any ideas? Tried going up a steep hill today almost didn't make it.
c-l
Ottawa Fiero Club President
« Reply #1 on: August 24, 2007, 07:24:37 pm »
Hey Tibs,
Mine did that a few times in the last 20 years. It starts like that and quickly gets worst. Both times, the problem was traced back to a clogging catalytic converter. Easy test - open up your exhaust past the Y pipe, put on a good set of hearing protector and go for a ride. If you can go over 4000 rpm... I'd take a good look at that cat !
« Reply #2 on: August 24, 2007, 07:30:34 pm »
Or hit the cat from underneath to see if it rattles.  If it's fairly old, it wouldn't hurt to change it.  No more etesting so I guess you could hollow it out if you wanted.
lsixtyseven
« Reply #3 on: August 24, 2007, 07:37:24 pm »
I'm going take a look at the cat, i hate cats.  Grin
lsixtyseven
« Reply #4 on: August 24, 2007, 07:42:09 pm »
Does anyone know the size of the exhaust pipe?
« Reply #5 on: August 24, 2007, 09:45:06 pm »
1 7/8" inside diameter.
lsixtyseven
« Reply #6 on: August 25, 2007, 05:13:27 pm »
Well it seems that the cat was the culprit, the car never ran so good and loud. Afro
