April 26, 2025, 06:50:41 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: New Shift Boot and Knob « previous next »
Author Topic: New Shift Boot and Knob  (Read 2111 times)
CKappa
« on: September 26, 2007, 01:48:06 am »
So i bought a new shift knob and shift boot and before I put them on i was wondering if they make aftermarket short shifters or do i just chop it all off
« Reply #1 on: September 26, 2007, 09:32:49 am »
You can purchase a couple of different pre-made short shifters from Rodney Dickman.
If you have access to a welder, it's easy to shorten the original shaft & re-attach it to the base.  Not to mention that cutting off the old threaded end & welding on a bolt with more common diameter & thread pitch will make fitting aftermarket knobs easier.
Whomever designed the shifter may have had penis envy...  the threaded end of the shaft is larger in diameter than just about everything out there, including other GM shifter knobs.   Roll Eyes
CKappa
« Reply #2 on: September 26, 2007, 04:03:52 pm »
lol thanx im gonna be ordering the hurst shifter anyways thanx for the link
