October 31, 2024, 10:28:55 pm
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: looking for somebody for some electrical repair work « previous next »
Author Topic: looking for somebody for some electrical repair work  (Read 2684 times)
Sock Rocker
« on: December 15, 2008, 03:35:40 pm »
Hi everyone I'm having some problems with my 3800 s/c and was wondering
If anybody could recommend a good mechanic?
The tiny storm in your teacup
1985 Coupe 2.8
1987 coupe 3.8sc
1985 Coupe dead and mostly gone
1984 coupe donor car
« Reply #1 on: December 15, 2008, 05:07:54 pm »
Most mechanics and garages won't touch a modified car like a 3800SC Fiero unless you know them or they have worked on one before.
If you want to bring your car down to my place I can help you out or tell me what is wrong and I might be able to tell you how to fix it your self. Dan
« Reply #2 on: December 15, 2008, 05:23:35 pm »
wondering
Must resist the urge to post...........................   Cheesy
Sorry Dan   Kiss
Sock Rocker
« Reply #3 on: December 16, 2008, 12:55:52 pm »
Well the car has spark and fuel but the injectors aren't firing i think and this problem has been intermittent for some time now and it decided to just stop working.  As for working on it myself i don't have the time and It's sitting in a heated garage because the car has water all through the cooling system so i basically Just need somebody who is willing to take the car fix it and flush the cooling system so it can be stored for the winter Tongue.
Chris
1985 Coupe 2.8
1987 coupe 3.8sc
« Reply #4 on: December 17, 2008, 02:15:35 pm »
You can bring the car to my place if you don't mind the long trip in the snowy weather or drain the water and wait till spring to see about getting her all fixed up. Dan
Sock Rocker
« Reply #5 on: January 01, 2009, 11:43:45 pm »
Hey dan sorry its takin me so long to reply but the holidays have been busy
I have the car all loaded on to a trailer and ready to go so if you still have the time and the space to
Take the car just call my father at 613-769-3696 and one of us can bring the car down
Cheers
Chris
Oh ha my dads name is doug
1985 Coupe 2.8
1987 coupe 3.8sc
« Reply #6 on: January 02, 2009, 11:53:06 am »
I have to finish off one car which should be done and gone early next week, so any time after that your car can come down and go straight into my gaqrage. unless you don't mind your car sitting in the drive way for a few days before going into the garage then any time is good to bring her down.
I will try and call tonight. Dan
Sock Rocker
« Reply #7 on: January 03, 2009, 01:42:16 am »
Hey dan since the car is filled with water I think we can wait for the garage lol.
I let my dad know to expect your call and well see you next week hopefully
Cheers
Chris
1985 Coupe 2.8
1987 coupe 3.8sc
« Reply #8 on: January 03, 2009, 07:17:49 pm »
It may be just me....but....
Leaving it with just water in the system is just asking for trouble.  It takes no time at all for a small passage or hose to freeze.  Dan's garage isn't a spa.   Roll Eyes
« Reply #9 on: January 03, 2009, 10:02:35 pm »
I would have to agree with Gary, chances are some thing will freeze up just on the trip down here. Drain the water, I can always fill the cooling system while I am working on your car.
Unfortunately I have been late working in the garage so I have not found the time to call your dad yet, hopefully I willhave some time tomorrow. Dan
« Reply #10 on: January 04, 2009, 10:11:53 pm »
Corrosion begins within 24 hours unless the concentration of glycol is at least 40%.  Freeze damage will occur overnight.
« Reply #11 on: January 05, 2009, 10:06:33 am »
The only time I have just water in any engine is while flushing out all the dexcool crap then the block is drained and properly filled with prestone/water mix.
Just drain all the water and bring along two jugs of prestone and I will fill and burb the cooling system while your car is here. Dan
