April 05, 2025, 02:25:16 am
Ottawa Fiero Club Forum  |  General  |  Project Work Logs  |  Topic: "A work in progress" or the story of the Thestral Fiero « previous next »
Pages: 1 ... 3 4 [5] 6 7 ... 10 Go Down Print
Author Topic: "A work in progress" or the story of the Thestral Fiero  (Read 54024 times)
falcon_ca
« Reply #60 on: June 23, 2009, 10:24:19 pm »
« Last Edit: May 02, 2010, 05:38:35 pm by falcon_ca » Logged
Restoration Formula
4.9 Ongoing project
falcon_ca
« Reply #61 on: July 03, 2009, 11:29:44 am »
I finaly found time for the coil-over.
I removed the red boots and the kit swivel head. They are now Chapman instead of MacPherson. Wink.
side by side:
Installed:
comparing gabs
Road test and final adjustment left to do.
« Last Edit: May 02, 2010, 06:22:32 pm by falcon_ca » Logged
Restoration Formula
4.9 Ongoing project
falcon_ca
« Reply #62 on: July 12, 2009, 02:54:31 pm »
Official 2009 version of the Sombral  Smiley
« Last Edit: May 02, 2010, 06:36:32 pm by falcon_ca » Logged
Restoration Formula
4.9 Ongoing project
falcon_ca
« Reply #63 on: August 12, 2009, 09:35:26 pm »
New wheels  Smiley
Ikon Storm 21 with 4 Linglong L688 215/45ZR17
« Last Edit: May 02, 2010, 06:41:58 pm by falcon_ca » Logged
Restoration Formula
4.9 Ongoing project
Bradtholomew
« Reply #64 on: August 13, 2009, 12:29:34 pm »
Wow, nice clean notchy.  I like...
« Reply #65 on: August 13, 2009, 07:24:48 pm »
Amen to that!
falcon_ca
« Reply #66 on: August 13, 2009, 08:26:01 pm »
Cool Cool Cool Cool T h a n k s   Cool Cool Cool Cool
BTW: Big brakes are coming this week-end  Wink
Restoration Formula
4.9 Ongoing project
falcon_ca
« Reply #67 on: August 16, 2009, 04:56:23 pm »
Problem:  Bottom of the 12inches brake hit the bottom arm when suspension is under charge.
Have to modified bottom arm.  Sad
I tried to correct the problem with a hammer but that is not enough, the problem also appears in curves, so the bottom control arm needs to be modified a little bit.
« Last Edit: May 02, 2010, 06:46:33 pm by falcon_ca » Logged
Restoration Formula
4.9 Ongoing project
« Reply #68 on: August 18, 2009, 01:47:38 am »
Are those the 88 12" rotors?
falcon_ca
« Reply #69 on: August 18, 2009, 05:13:06 pm »
If you mean C4 Corvette 12" brakes for 88, using 88 calipers, the answer is yes.
Restoration Formula
4.9 Ongoing project
« Reply #70 on: August 19, 2009, 10:49:47 pm »
It might be less work to put the old ball joints back in and cut the springs.
falcon_ca
« Reply #71 on: August 20, 2009, 07:28:24 pm »
I dont think so.
A series of  well placed hammer blows, or a "massage" as Rodney Dickman told me, will correct the problem.
Restoration Formula
4.9 Ongoing project
« Reply #72 on: August 20, 2009, 10:23:16 pm »
Make sure you check your clearance with the steering all the way left and right.
falcon_ca
« Reply #73 on: August 21, 2009, 05:25:33 pm »
Of course, and also with the suspension fully down.
It is getting closer as the suspension goes down.
Restoration Formula
4.9 Ongoing project
falcon_ca
« Reply #74 on: August 22, 2009, 07:32:12 pm »
Rear was much more easier than the front will be.  Smiley
I like the look  Cool
« Last Edit: May 02, 2010, 06:49:35 pm by falcon_ca » Logged
Restoration Formula
4.9 Ongoing project
Pages: 1 ... 3 4 [5] 6 7 ... 10 Go Up Print
