April 05, 2025, 02:41:59 am
Ottawa Fiero Club Forum  |  Off Topic  |  Other  |  Topic: Discount/wholesale batteries « previous next »
Author Topic: Discount/wholesale batteries  (Read 4041 times)
« on: October 08, 2009, 09:59:58 am »
Does anyone know where 12v deep cycle batteries can be had at sub-retail prices?
I'm looking for a sealed 12v 100aH (deep cycle) battery.
Vented batteries which meet this spec are easy to find and can generally be purchased for $100ea or less; as soon as the word "sealed" enters the conversation however, the price triples.   Roll Eyes   Sad
« Reply #1 on: October 10, 2009, 12:29:42 am »
Have you tried Total Battery or Canadian Battery?
100 Amp Hour is a big battery.  How many are you looking for?
« Reply #2 on: October 11, 2009, 09:12:13 am »
Total Battery has what I'm looking for, to the tune of about $350ea taxes-in.
These things are typically used as storage batteries for residential wind & solar rigs, but I'm looking for one to use as the source for a UPS for our pellet stove.
I explored hitting Princess Auto's surplus section and running a number of 3-5aH batteries in parallel, but there are no gains as far as cost goes, and space rapidly becomes a problem.
« Reply #3 on: October 12, 2009, 01:29:12 am »
There are very specific limitation as to charge and discharge cycles on a lead-acid (or like) battery.  Basically you should never discharge a 12V battery passed 10.5V (or it will never recover fully).  So what are your amp-hour calculations based on?  Typically you only get about 2/3 of the rated capacity of a battery before you damage it.
Also you can get 3 to 10 times the charge cycles out battery if you never discharge passed half.
« Reply #4 on: October 12, 2009, 08:18:56 am »
The UPS manages the charge/discharge cycle, which given the manufacturer's reputation and the battery life I've experienced with other UPSs of this brand, I suspect  is handled reasonably well.  The user manual for the thing doesn't go in to specifics, and they do not appear to supply this information online either.
I made no amp-hour calculations; simply selected the battery capacity based on what appears to be a commonly available deep-cycle battery intended for indoor use.
It's easy to cut the price by a 1/2 to 1/3 if a non-sealed battery would do.  Marine deep cycle batteries are a dime-a-dozen by comparison.  I'm not willing to take a chance on electrolyte vapor or hydrogen being vented in to the room however.
« Reply #5 on: October 15, 2009, 12:22:22 am »
Wear a mask Tongue
