April 15, 2025, 08:42:20 am
Ottawa Fiero Club Forum  |  General  |  Mods  |  Topic: HOLLEY BIG BORE THROTTLE « previous next »
Author Topic: HOLLEY BIG BORE THROTTLE  (Read 3823 times)
Rebel
« on: February 18, 2003, 10:06:56 pm »
any one  ???out there no if it worth putting a HOLLEY BIG BORE THROTTLE on a 2.5
Any info on this coversion will help
thanks Marcel Grin
« Reply #1 on: February 18, 2003, 10:14:58 pm »
I doubt it.  Maybe you could just get someone to help push the car.  Grin
Gosh I'm witty!
CaddyRob
« Reply #2 on: February 18, 2003, 10:48:00 pm »
In combination with other mods the bigger bore throttle body is worth it, but on its own, I would say no. Now if you got a header, and ported out the head and did some intake work, you may find it worth the bigger bore.  It has to be part of a package, its no wonder mod!
Later;
« Reply #3 on: February 18, 2003, 11:03:24 pm »
yeah for $350US I don't think you get much increase,  for $350 you can get a pile of Type-R stickers Wink
I've heard some say boost the 92 horses to 110-120 but others mentioned not that much
If you go on PFF you will find thousands of threads, some suggest Cam swap, check it out. Was never intended to be a powerful engine and there are restrictions, plus with gas prices may not be a bad idea to mod for mileage.
« Reply #4 on: February 19, 2003, 09:13:32 am »
if you are going to tear in there and put a cam and all, whay not tack on at least another 2 cyl.? at least drop a 2.8 in there. Wink
« Reply #5 on: February 19, 2003, 09:58:36 am »
CaddyRob is right; it will only pay off if it is done in conjunction with other mods that create freer flow - head porting, maybe intake manifold porting; headers or improved exh system; and a CAM to make the engine breathe deeper.  By itself (if you go TOO big) it might even create driveability problems - air velocities at idle and low spd might not be high enough etc.
Good luck and keep us posted on what you do and how it turns out!
