November 02, 2024, 12:38:04 pm
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: Hey all « previous next »
Author Topic: Hey all  (Read 1759 times)
dutch13
« on: May 02, 2010, 10:17:35 pm »
Hey guys,  so i've been reading your threads for a while now and as i have been hunting for a fireo i finally found one and decided it was time to open my mouth and say hi.  My name is Corey and i live in orleans.  I just picked up my 86 fiero gt today and the fun begins.  I'm currently in the process of building a 3400 sfi engine to swap into the car but im waiting on parts so for the meanwhile the cleaning up has started.  I'll post a few pics in a bit.
FIERO-JOE
30 years old!!
« Reply #1 on: May 03, 2010, 10:15:42 am »
well hello back..
where abouts in orleans r u??? im near 10th line and innis..
there is a purple fastback on my street.. and
i have seen a gold/silver.. tarnished one near trim.. is that you???
well.. welcome...
joe   Grin Grin
dutch13
« Reply #2 on: May 03, 2010, 05:41:20 pm »
just off tenth line as well.  I just baught a black gt.  Its got no engine in it yet lol so your yet to see me.
« Reply #3 on: May 03, 2010, 05:52:09 pm »
Congrats;
It's good to see more Fieros getting on the road in the area.  I'm in Blackburn.
Good luck.
« Reply #4 on: May 03, 2010, 07:51:16 pm »
Welcome to the madness, if you are looking for an engine I have a nice 3.4 DOHC from a 97 Monte here that is almost done being wired up for a Fiero swap using a manual 5 speed tranny. Dan
FIERO-JOE
30 years old!!
« Reply #5 on: May 03, 2010, 09:05:39 pm »
how much dan?Huh
« Reply #6 on: May 04, 2010, 12:58:39 pm »
$600 for the engine with the wiring harness to fit in an 85 to 88 Fiero.
The engine already has a mount bracket made up so mounting will not be an issue and if you want the 5 speed Isuzu to go with it its an extra $100. Dan
dutch13
« Reply #7 on: May 07, 2010, 08:36:45 pm »
Thanks for the offer but im already in the process of building a 3400 turbo... just waiting for my pistons and the time of day to put it all together.
Figured i'd post a pic... needs quite a bit of work.  The engine was already removed for the car when i baught it.  I just started taking everything apart and I'm trying to work on the typical rusted areas.  Random question,.. the strut bolts slide out like everyother gm and arn't threaded all the way through right?, they just need some pursuasion?!
« Last Edit: May 07, 2010, 08:42:22 pm by dutch13 » Logged
« Reply #8 on: May 08, 2010, 11:22:17 am »
Correct.  The warmer the persuasion, the better.
« Reply #9 on: May 08, 2010, 01:15:02 pm »
get the nut loose before you try working on the bolt.
