I just got an idea guys!
#1 kille of Fiero's is the heat... you throw a belt, water pump dies, whatever, she starts cooking and the there is a little grmlin knocking in your engine.
I just came up with schematics for a backup system in my head.
Mount an electric waterump up front by the rad. When all is good, it does nothing.
Pickup a temp switch for a few degrees above what is acceptable temp for a Fiero engine, wire it to a relay. if the engine starts to overheat (the belt slipeed, whatever) it will trigger the electric pump relay and you can safely get home! I would also wire a LED to the relay so that you have some kind of blinking light to let you know the system is saving your butt.
what do you think?
