April 18, 2025, 04:39:17 pm
Ottawa Fiero Club Forum  |  Buy/Sell/Trade  |  Parts  |  Topic: Free to a good home « previous next »
Author Topic: Free to a good home  (Read 6884 times)
« on: August 20, 2010, 06:11:33 pm »
Free to a good home between now when I do my next disposal run.
  • one left door,  glass is good, latches may be ok, hinges useable with new bushings.  No skin, mirror, or interior components.
  • one right door,  glass is good, latches may be ok, hinges useable with new bushings.  No skin, mirror, or interior components.
  • Pre-88 front crossmember.  Includes all front suspension components; no calipers.  Free if you pick it up; if I have to wrestle it on to the trailer & deliver it'll cost you a 2-4.  gone
  • 3 pre-88 front calipers, useful as cores only.  All seized, no hardware.  gone
  • 1 pair (left + right) pre-88 rear calipers.  E-brake mechanism seized.  gone
  • 87 2.5L block, or any components of it which you care to remove.  200,000+km, crank will not rotate by hand.  gone
  • 1 pair pre-88 strut & knuckle assemblies.  Hubs rotate freely.  gone
  • 2 1985+ driver's side door skins, damaged at areas circled in photos below.  gone
  • 3 front fenders, damaged at areas circled in photos below.  gone
« Last Edit: April 16, 2013, 10:52:04 am by dguy » Logged
c-l
Ottawa Fiero Club President
« Reply #1 on: August 20, 2010, 08:26:53 pm »
I just so happen to need one !
PM sent
« Reply #2 on: July 24, 2011, 08:11:59 pm »
PM sent.
« Reply #3 on: July 27, 2011, 10:54:15 am »
PM sent
« Reply #4 on: August 16, 2011, 08:31:26 pm »
P.M. Sent
grandam455
« Reply #5 on: December 14, 2011, 09:33:42 pm »
dguy is the 2.5 block still around if so i would be intrested. Thanks Tom
« Reply #6 on: December 15, 2011, 02:45:32 pm »
I'm sure he still has it hanging on the end of a chain tethered to his boat.
Couldn't resist......sorry.
« Reply #7 on: December 16, 2011, 06:29:31 am »
^^^ Grin
Yes Tom the block is still available.  It can be picked up most evenings and weekends, just outside of Carleton Place.  PM with contact info coming...
grandam455
« Reply #8 on: December 16, 2011, 10:33:53 pm »
got it thanks
« Reply #9 on: January 02, 2012, 03:08:05 pm »
updated... the block is now gone.  all which remains are the calipers.
« Reply #10 on: January 02, 2012, 04:19:17 pm »
Is that because the chain was too rusted to extract the anchor?
grandam455
« Reply #11 on: January 05, 2012, 08:57:27 pm »
Sorry dguy about not getting there on time but i got talking to cory about his car and learning alot about these cars and alot still to learn, Thanks Tom
« Reply #12 on: January 06, 2012, 10:54:13 am »
No problem Tom, it went to a good home.  Someone whose Duke had shredded the nylon cam gear got a hold of me through other channels and picked it up.
87GT
« Reply #13 on: April 21, 2012, 11:04:29 am »
dguy,
Do you still have the pre 88 rear calipers?  I'm looking for the e-brake levers and brackets which bolt to the caliper.
Thanks,
Gord
« Reply #14 on: April 22, 2012, 05:37:53 pm »
Hi Gord... yes the pre-88 rears are still here.  PM coming...
