April 19, 2025, 08:11:14 am
Ottawa Fiero Club Forum  |  Buy/Sell/Trade  |  Parts  |  Topic: WTB 5 speed Getrag parts « previous next »
Author Topic: WTB 5 speed Getrag parts  (Read 2526 times)
falcon_ca
« on: September 29, 2010, 08:44:43 pm »
I had a quick chat with the guy who is doing the rebuilding of my 88 Getrag and he told me that this transmission had already been opened and the output shaft disassembled, because the first rebuilder had inverted the 1st and 5th pin bearings, probably causing the breakage of one of the bearing.
So I am looking for maybe both bearings, GM parts are 10051601 (1st) and 9441543 (5th) or a complete output shaft.
They are parts 39 and 50 in the Muncie Product Service Training Guide.
« Last Edit: September 29, 2010, 09:15:20 pm by falcon_ca » Logged
Restoration Formula
4.9 Ongoing project
« Reply #1 on: September 30, 2010, 10:39:09 pm »
I've only seen bearings available in rebuild kits.
« Reply #2 on: October 02, 2010, 10:15:39 pm »
If you're up for the surgery, disassemble the transmission & take note of any id numbers inscribed on the bearings you wish to replace and contact General Bearing Service.
I did this when I refreshed the guts of the 4-speed for my L67 project, and GBS was able to source a replacement for every bearing in there.  Good luck!
falcon_ca
« Reply #3 on: October 03, 2010, 08:51:43 pm »
No number on this one and nobody have it based on GM number.
So I am looking for a used one or maybe a complete output shaft.
Restoration Formula
4.9 Ongoing project
