April 03, 2025, 10:45:43 pm
Ottawa Fiero Club Forum  |  Off Topic  |  Other  |  Topic: Small engine experts needed « previous next »
Author Topic: Small engine experts needed  (Read 4415 times)
« on: January 01, 2011, 11:41:20 am »
I have a generator powered by a 10hp Tecumseh.  It is the loudest freaking thing I ever heard.  My ears still hurt from a 5 minute run.
Is there some sort of exhaust system or muffler that I can use rather than the OEM tiny can?
Advice welcome
« Reply #1 on: January 03, 2011, 09:59:22 am »
Can you split the "muffler" in a non-destructive way, and pack it with exhaust fiberglass wadding?
lercs
« Reply #2 on: January 03, 2011, 05:09:51 pm »
Most of the more expensive generators have an insulated case. You could try building something like that.
« Reply #3 on: January 04, 2011, 12:06:29 am »
If you don't find a bolt on solution I can make you a custom exhaust for the cost of the metal.  I need to run an exhaust experiment anyway.
« Reply #4 on: January 04, 2011, 12:26:18 pm »
That would be very nice, Aaron.  I figured on build an insulated box that I could use here at home.  I got the darn thing before the ice storm.  We dragged it from house to house running the sump pumps.  It's heavy and awkward.  I have it sitting on a small garden cart now, but the wheels aren't made to drag thru snow or mud.
I hoped to use it to run the little MIG welder I picked up., if I ever get a small tank to use with it.
Some solutions I ran across for varying sizes of generators ranged from a 45 gallon drum, a dug pit covered with planks and a long hose attached to a small generator.
Mine is a Devilbis 5000 with a 10hp Tecumseh. It's a bugger to pull at -40
p.s. ear still is ringing.  Gary
