April 12, 2025, 02:17:58 pm
Ottawa Fiero Club Forum  |  General  |  Mods  |  Topic: Lambo doors, sissor kit?? « previous next »
Author Topic: Lambo doors, sissor kit??  (Read 11261 times)
FIERO-JOE
30 years old!!
« on: January 28, 2011, 07:20:37 am »
hey all i was looking at the possibility of going lambo sissor doors.. found the kits pretty cheap but looking at the pros and cons of having those doors installed..
any input and or attempts good or bad would help
thanks
joe
88formula
« Reply #1 on: January 28, 2011, 11:33:52 am »
im interested in what everyone who has them has to say...
maybe one day in the future Smiley
c-l
Ottawa Fiero Club President
« Reply #2 on: January 28, 2011, 04:53:02 pm »
The Fiero Montréal president had them on one of his car when he bought it.... first thing he did was take them off.
Door was heavy to lift from inside the car...  no woman could get out the passenger seat without him having to open the door from the outside.... you had to be very carefull to open the door fully outward  (as far as it will go that is, about 15cm) before starting to lift it, otherwise it would rub on the upper section of the fender.... he really lost it and decided to rip them out, the third time the driver side door fell on him as he was climbing into the car  Angry
Let us know how your's turn out.
« Last Edit: January 28, 2011, 04:56:09 pm by c-l » Logged
falcon_ca
« Reply #3 on: January 30, 2011, 11:42:29 am »
I am installing a set on my Formula. This kit is equiped with 2 struts for a total of 280 pounds, making the doors really easy to manipulate.
Of course you have to be carefull when you close the door, making sure it is completely down and aligned.
The kit I bought is made especially for the Fieros, and is known as been "bolt on"  but of course requires some adjustement and dexterity.
Pictures in my main post in french : http://www.fieromontreal.com/smf_forum/index.php?topic=1200.600
Restoration Formula
4.9 Ongoing project
FIERO-JOE
30 years old!!
« Reply #4 on: January 31, 2011, 10:13:28 am »
cool so u have done it already?? how dificult was the install???
easy too hard??? i was looking on ebay for the lambo door kit with struts??
is it worth getting???
 joe
falcon_ca
« Reply #5 on: February 01, 2011, 10:28:16 pm »
I bought my kit from Jessy on PFF http://www.fiero.nl/forum/Forum1/HTML/078049.html
Very good product made by a Fiero man for Fieros.
Jessy is very easy to deal with and is behind his product.
They are "bolt-on" but of course some fine adjustments are required.
I am almost done.
My friend Danyel from Quebec City area also did the mod last year.
« Last Edit: February 07, 2011, 10:47:42 pm by falcon_ca » Logged
Restoration Formula
4.9 Ongoing project
Church
WWW
« Reply #6 on: February 20, 2012, 09:51:48 am »
thanks
joe
Look at the butterfly door kits as well, much more unique and rare
Fred
« Reply #7 on: February 20, 2012, 01:52:52 pm »
One thing c-l forgot to say is that he used an upgrade for the strut (Stiffer, that can lift more weight) but we know that all the system was poorely installed. Therefore make sure that if ever you make the installation, you know what you are doing or your asking a professionnal to do it.
There are 2 kinds of kits available on the market. The one with the picture of the red car you posted are opening streight. They are very vertical when you look at it from the front of the car. You can have them by "GT Factory". http://www.gtfactory.jp/diablo.htm It would look like the first picture I'm posting.
The second kind is like falcon's which isn't aligned vertically. If you would look at it from the front of the car, you would see that there is a small angle that when open, the bottom of the door and the top of the door arent in a vertical line. Its a little tilted to the outside. Like the 2nd picture I am posting. Note: most kits are like that.
The 3rd picture is an explenation between both of them if my description wasn't enough or you're more visual. (Found on the GT Factory website) Note: You need to download this picture. It's called: DBL_03.tif
The modification I wanted to make on my car was to put gullwing doors just like the DMC DeLorean. Though the fiero doesn't have a frame around the window therefore it can't receive hinges to the top of the door. GT factory makes a "gullwing" kit for those kind of application. Found here: http://www.gtfactory.jp/gullwing.htm Or look at the last picture!
I find it much more different and more interesting to work with. Though I think there was only one application of a kit like that on a fiero. I havent found any feedback or anything. It would be more complex and a longer project. (Less "bolt-on")
Fred
« Last Edit: February 20, 2012, 01:54:53 pm by Fred » Logged
Pontiac Fiero GT 1987
Danyel
Fiero Beginner
« Reply #8 on: April 10, 2013, 10:36:59 am »
I love mine and have NO issues with them ... carefull installation required ...if you do a halfass job the doors wont close or open correctly ...
 regards
Danyel
