October 31, 2024, 11:36:24 pm
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: Cradle Bushings « previous next »
Author Topic: Cradle Bushings  (Read 1771 times)
« on: April 23, 2012, 12:08:41 pm »
Is it possible to change them without dropping the cradle completely out? It's been awhile since I have been under there to look. Also does anyone know the dimentions of the aluminum ones? Or have a set they want to measure for me? That's the first thing I was thinking of making when I get my lathe hooked up. (Waiting on the electrician) Angry
Dan
« Reply #1 on: April 23, 2012, 06:34:17 pm »
Yes they can be changed by just lowering the cradle a few inches but it is not easy to get the old ones out that way. Dan
c-l
Ottawa Fiero Club President
« Reply #2 on: April 23, 2012, 06:35:28 pm »
yes... but it is more of a pain.
Edit: You beat me to the punch Dan
« Reply #3 on: April 27, 2012, 03:25:11 pm »
Get yourself one of these:
http://www.princessauto.com/pal/product/8309338/Steering-%26-Suspension/Ball-Joint-Remover-%26-Installer-Set
and use some heat if you have to.  But be careful with the heat and where you point it.
« Reply #4 on: April 27, 2012, 06:20:36 pm »
Good idea Aaron. I could probably borrow one of these from my buddy.
