April 12, 2025, 08:40:48 pm
Ottawa Fiero Club Forum  |  General  |  Mods  |  Topic: need advice « previous next »
Author Topic: need advice  (Read 7022 times)
grandam455
« on: May 28, 2012, 11:43:11 pm »
I have a chance to get a front nose from a 85gt will this fit on the 84 notchie,also the rear bumper and the rear truck lid work? Thanks Tom
Dan
« Reply #1 on: May 29, 2012, 08:15:43 am »
Only difference is the grate on the trunk lid and make sure you get the plastic pieces from under the bumpers so they bolt up straight. Dan
grandam455
« Reply #2 on: May 29, 2012, 06:59:54 pm »
Thanks Dan I was also given working headlight motors, also gas tank and pump and coolant tubes,and calipers,they are the same? Thanks Tom
« Reply #3 on: May 30, 2012, 12:06:48 am »
All the same except I'm not sure about the headlight motors, but even if they are different they should still work (ie: bolt right in).
It's very important that you get all the underling plastic pieces that locate the outer panels for the body swap.
grandam455
« Reply #4 on: May 30, 2012, 08:40:32 pm »
Thanks for the advice was not sure if they would interchange but i do like the G.T. front and rear fascia. There is a trans. out of the car will it work to, it was from a 2.8 and i have the 2.5 Sorry about all the Question but he calls everyday telling of parts he found in his barn and i'am not a expert, Again thanks guys for your advice
« Reply #5 on: May 30, 2012, 10:38:10 pm »
Auto or manual?
grandam455
« Reply #6 on: May 30, 2012, 11:55:39 pm »
It is a auto.
Dan
« Reply #7 on: May 31, 2012, 07:25:30 am »
2.5 and 2.8 used the same auto tranny so it will work fine. Dan
grandam455
« Reply #8 on: May 31, 2012, 08:47:38 pm »
Thanks Dan,My reverse is slipping alot thats why i needed to know.
