April 19, 2025, 03:02:24 pm
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: 4cyl. « previous next »
Author Topic: 4cyl.  (Read 2989 times)
grandam455
« on: June 05, 2012, 11:24:26 pm »
Would a 87 4 cyl. auto work in 84, sensors? same drivetrain except roller lifters thanks Tom
« Reply #1 on: June 06, 2012, 12:42:41 am »
According to Dan it should be the same.  If you are still in doubt, call GM or NAPA and see if the part numbers are the same.
http://www.fierodrivers.com/forum/index.php?topic=4304.0
Dan
« Reply #2 on: June 06, 2012, 01:07:37 pm »
87/88 used a different throttle cable and had ignition modules over distributors so no the 87 duke will not work in an 84 to 86 Fiero with out some wiring work, an ECM change and a different throttle cable. Dan
« Reply #3 on: June 07, 2012, 10:53:06 pm »
I think he's just talking about the transmission?  Maybe not.
Edit:  Okay I see he mentioned rollers
« Last Edit: June 07, 2012, 10:54:38 pm by aaron88 » Logged
grandam455
« Reply #4 on: June 08, 2012, 10:17:00 pm »
Thanks guys so only the 84-86 engines
