Fred
« Reply #17 on: May 08, 2014, 03:13:08 pm » |
Hi Guys, Aaroon, I sent you a text message for a quick reply but i don't know if you have the same phone number. I had a question that I'm sure either you or Dan could answer. I don't remember what kind of clutch I need to use for the F23 swap. There are a lot of confusion on the forums. I wish to go with the Spec Stage 3+ (From what I heard, it is more streetable than the Stage 3) From what I remember, the one to use was the stock 2.8L 5spd clutch. ( http://www.specclutch.com/cars/Pontiac/Fiero/1987/Single) Now the question that I have, do I need the "Additional Clamp Load Upgrade" that I'm guessing would be the "Super Clamp" Pressure Plate that can be seen here: http://www.specclutch.com/products. From what I saw, The aluminum pressure plate doesnt clear the differential "Hump" inside the transmission's bellhousing but the "Super clamp" does due to its different shape. Thanks again for the support!  Fred
Pontiac Fiero GT 1987
Fred
« Reply #20 on: May 10, 2014, 12:57:08 pm » |
Dan, Thank you for clearing things up. It's good to hear from someone who already did the swap. The confusion about clutches in this swap is extremely high. I also talked to Aaron as well as reading old PMs you sent me, Every info that I have regarding the clutches are the fallowing: (I've also found pictures) Spec Stage 3 or Stage 3+ clutch for a Pontiac Fiero 2.8L 5spd application. It is important that the pressure plate cover has a round shape, not a spiral star (Or saw tooth as Dan described). The first 4 pictures are from the spiral star design and is known to causes clearance issues. The bellhousing had to be grooved and even then it still caused interference. The 5th and last picture is the correct one to buy. I'm in discussion with Spec to order and make sure it's the correct design for my application. Thanks again guys!  Fred
