November 02, 2024, 08:35:13 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: Trans. Problems « previous next »
Author Topic: Trans. Problems  (Read 1700 times)
grandam455
« on: December 12, 2012, 05:07:34 pm »
I took the car out for a quick spin got ten blocks and the trans.kicks out no forward or reverse.Check fluid it was fine,Shut car off walk to store to call home, Well get back and i tried it works great until a block from home and it cuts out again,hour later she works for about 8-10 min. then nothing any ideas, sensor maybe? Thanks Tom
Dan
« Reply #1 on: December 12, 2012, 07:21:12 pm »
Could be a sensor or a bad pump failing once warmed up or even a bad torque converter either way it is most likely some thing internal requiring the tranny to be dropped or disassembled in some way. Dan
grandam455
« Reply #2 on: December 12, 2012, 09:08:37 pm »
Thanks Dan also you can hear a scrapping kind of sound when it kicks out, i have a auto out of 85 2.8 that will bolt up to the 2.5? Thanks Tom
