April 03, 2025, 10:34:24 pm
Ottawa Fiero Club Forum  |  Off Topic  |  Other  |  Topic: 1999 series II just died « previous next »
Author Topic: 1999 series II just died  (Read 5673 times)
grandam455
« on: May 29, 2013, 10:32:04 pm »
 My daily driver 99 grandprix with the series II just died, fuel pump works and spins normal when trying to start, No spark so I believe it would be a crank sensor or cam sensor how would you check before trying to change it. Any advice would be great thanks Tom.
Dan
« Reply #1 on: May 30, 2013, 08:45:44 am »
Is there any codes to read
grandam455
« Reply #2 on: June 02, 2013, 10:44:23 am »
No codes Dan that's what is confusing, when rolling over tach. should work?  barley budges which has me thinking it could be cam sensor really could use your advice, thanks Tom
Dan
« Reply #3 on: June 02, 2013, 11:35:11 am »
With no tach it is definitely in the cam/crank sensor area or the ignition module itself. Dan
grandam455
« Reply #4 on: June 02, 2013, 08:16:52 pm »
ignition module is that the coil packs? not sure, I guess I worked on to many old cars with points
Dan
« Reply #5 on: June 03, 2013, 08:57:14 am »
Ignition module is under the coils, basically the base of the coils. Dan
indypacecar
« Reply #6 on: June 03, 2013, 06:51:04 pm »
Crank sensor is the most common ( with no codes )
Have had it happen to our cars a couple of times. Good luck with the fix !
grandam455
« Reply #7 on: June 03, 2013, 09:03:58 pm »
Thanks Dan for your advice and I will replace the  crank  sensor this weekend, The wife wants here van back
