April 18, 2025, 07:44:05 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: Not Starting « previous next »
Author Topic: Not Starting  (Read 3265 times)
grandam455
« on: May 25, 2014, 08:38:59 pm »
About 3 weeks ago started car and it was running rough, Just thought it was from sitting the winter, Try to start today and it just rolls over. Checked shrader valve lots of fuel so what would be next, There is no spark, Sorry car is 84 4 cyl. coil? or distributor cap? could use some advice to were to look first. Thanks Tom
« Reply #1 on: May 27, 2014, 12:30:51 am »
Check the voltage while cranking.  If it's too low 10V or lower the computer will not work, and won't fire the injectors.
If you have no spark, track it back one junction at a time.  If you have fuel, and air in the right ratio, any spark will ignite it.  So keep going back to that principal in your mind.  You are missing one of the components, or it's in the wrong ratio.
Get yourself a manual, any of them.  And follow the troubleshooting guide.  That should guide you through the process.
Good luck.
grandam455
« Reply #2 on: May 28, 2014, 11:02:41 pm »
Thanks Aaron yes battery was not up to a full charge should have charge before starting thanks will try tomorrow, Tom
