April 18, 2025, 08:03:48 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: Looking for a Fiero mechanic « previous next »
Author Topic: Looking for a Fiero mechanic  (Read 3893 times)
LenzTech
Fiero Beginner
Lens Ferrario
WWW
« on: August 29, 2014, 08:39:13 am »
Hi all,
I was wondering if there are any recommends for a mechanic in the Ottawa area. I need some rear axil work done.
Len
Len Gaultois   BSC, MEng
Lenz Computer and Electronics
       3796 Champlain St
    Bourget, On, K0A 1E0
          613 487 7888
jonracine
Fiero Beginner
« Reply #1 on: August 30, 2014, 03:30:39 am »
Hi Len,
We have a really good one a little West in Carleton Place, Ontario.
I use Wes whos been servicing my Fieros (and another friends 3800 Fiero project) at McIntosh Automotive for years.
He's the only mechanic I've found whos mastered the oddities of the Fiero.
Their number is 613-253-8109.  Well worth the extra trip for the quality he brings.
LenzTech
Fiero Beginner
Lens Ferrario
WWW
« Reply #2 on: September 06, 2014, 01:57:44 pm »
I started to work on my car today. I pulled the drivers side tire first and inspected everything. everything seemed ok. When I pulled the rear passenger tire I found the tire was trashed. It had broken its belts and was severely warped. I will try to attach pics.
       3796 Champlain St
          613 487 7888
« Reply #3 on: September 06, 2014, 03:01:06 pm »
Ya, that's really bad.
LenzTech
Fiero Beginner
Lens Ferrario
WWW
« Reply #4 on: September 11, 2014, 10:03:26 am »
The 308 has P225/50R15 tires on it. BUMMER - no tires available in Canada. I can have tires ordered from the US @ 479.oo per tire.. I am having P225/60R15s installed on the rear until I can find a good set of 4 @ a good price. The car will sit a bit wonky as the 60s are about one inch taller ~2 inch larger diameter. There seems to be lots of room for them in the wheel well.  Sad
       3796 Champlain St
          613 487 7888
« Reply #5 on: September 13, 2014, 08:24:52 am »
You should use 245/50/15 on the back and 215/60R15 on the front.  You will be much happier with the way that feels on the road anyway.  If you needed to you could also use 245/55R15 but that's slightly taller than stock Fiero.
Cheers,
