April 03, 2025, 11:12:10 pm
Ottawa Fiero Club Forum  |  General  |  Project Work Logs  |  Topic: 3800 Swap « previous next »
Author Topic: 3800 Swap  (Read 4776 times)
« on: September 14, 2016, 09:28:40 pm »
Well I've been able to work on my swap a bit in the last month and I finally got most of the engine done. Just mocked up the belt pulleys and low mount engine set up I got from Fierorog.
Still got a few things to paint on the engine yet, just wanted to make sure everything fit.
« Reply #1 on: September 17, 2016, 03:17:16 pm »
Looks nice and clean.
Dan
« Reply #2 on: September 17, 2016, 06:57:37 pm »
looking good but don't forget to swap valve covers from side to side to make oil changes a lot easier after the swap is done
« Reply #3 on: September 17, 2016, 10:10:32 pm »
Yeah just swapped the valve cover today actually.  Smiley
Dan
« Reply #4 on: September 18, 2016, 11:17:20 am »
hope you installed new gaskets and also replaced the lower intake gaskets with the newer aluminum ones as the engines like to leak fluids
« Reply #5 on: September 18, 2016, 09:01:06 pm »
Yeah I bought the complete gasket kit from top to bottom. The only thing I didn't do is pull the bottom end apart ie: bearings, rings, pistons.
