April 16, 2025, 07:52:48 am
Ottawa Fiero Club Forum  |  General  |  Mods  |  Topic: Mustange tri-light break lights « previous next »
Author Topic: Mustange tri-light break lights  (Read 4710 times)
FIERO-JOE
30 years old!!
« on: September 30, 2016, 07:48:58 am »
hey all I'm about to put in the tri-light breaking lights and turn lights, seen on the newer mustangs..
our fiero's have the same 3 light systems.. and well.. I can only assume the wiring systems are the same..
wish me luck..
« Reply #1 on: October 01, 2016, 01:57:53 pm »
Did you buy a kit? There was a plug and play kit available at one time.
« Reply #2 on: October 01, 2016, 07:00:20 pm »
Yes there was something, not sure if it's still available, but I do know that dguy installed something like that on his Fiero.
« Reply #3 on: October 01, 2016, 10:40:54 pm »
Yes, I nstalled a sequential turn signal on our '85 many years ago, (arguably) before it became a "thing" on Mustangs.
It was a relatively simple task - the notchback Fiero's three parallel-wired 2057 bulbs original connection to the rear light harness was cut, such that each ended up having a separate connection to the sequencing module.  If my memory is working there really wasn't much to the install if you are comfortable with side cutters and a soldering iron.
« Reply #4 on: October 03, 2016, 07:10:00 pm »
Just happened to see this on Pennocks
http://www.webelectricproducts.com/products.htm
If you look under the sequential tail light section they have ones for fiero's
« Last Edit: October 03, 2016, 07:12:03 pm by can machine » Logged
Dan
« Reply #5 on: October 04, 2016, 07:23:40 pm »
have them on my 88 formula and like the looks
monzaguy
Fiero Beginner
« Reply #6 on: November 25, 2016, 12:29:13 am »
the new mustang tri tail lights are NOT adaptable to our cars PERIOD. Maybe off an 86-89 cougar,T bird.etc would work with a lot LESS werk
Shiney side up greasy side down
