April 18, 2025, 07:31:37 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: clutch or slave issue « previous next »
Author Topic: clutch or slave issue  (Read 2949 times)
FIERO-JOE
30 years old!!
« on: September 18, 2017, 08:36:34 am »
hey all ok now the next issue.. I bought and installed a new clutch slave think I bleed the lines and that its working ok.. BUT still no clutch disengaging   the pedal goes to the floor with little to no resistance.. the slave moves but not very far...  maybe a inch total movement..
I never really looked to see how far everything moves when is was working so I have no clue as to the correct movement..
other then dropping the engine and pulling the tranny apart is there a way to test if its just air in the line or if its the clutch mechanics that is broken,,
thanks all..
« Reply #1 on: September 19, 2017, 06:15:29 pm »
If you don't have any leaks then it seems like air in the system to me.  Or it's possible you have the wrong slave (too large) or the wrong slave master (too small).
Only real possibilities.
