just checking to see what seems to be the popular setup for autocrossing; mostly spring rates, but if anyone has actually converted to coil-overs in the front, do you have any specs or stats on them? Overall length, travel, spring rate, etc?
I have seen front spring rates from (I think) about 250 lbs to over 400, so I am trying to get a 'feel' for how these different setups ride and handle.
I just got my front (right side only...) control arms off and am going to install poly bushings and coil overs; already have them but i KNOW I have to change the springs; they were for a front engine setup. Taking off control arms is one MORE thing I am not going to do too often. Yuchhhhh; what a job. Still have the left side to do mostly now but it will be worth it.
Big brake and maybe an entire spindle swap in the works at the same time. Hoping to find a good and inexpensive way to change to the standard chev 4 3/4 bolt pattern; THAT would be a bonus. Will keep everyone posted if I figure something out there.
