April 13, 2025, 11:23:27 pm
Ottawa Fiero Club Forum  |  General  |  Mods  |  Topic: lower control arms - let's try again « previous next »
Author Topic: lower control arms - let's try again  (Read 2449 times)
« on: April 28, 2003, 08:36:47 am »
this is to follow up/continue in my efforts to figure out why the lower control arms are like they are. I took a pic or two from a different angle to try to make up for my lack of command of the english language and to better explain my point. (see pix)
Look along the line of the straight rods; you will see the amount that the axes of the pivot points are "out of alignment". Pretty straightforward I think in this pic that they do NOT share a common pivot axis.
This would work OK if there were one-point bearings in place of the bushings, but with semi rigid (or rigid where aluminum is used Shocked !) bushings are going to be in conflict with one-another. So....... I am still puzzled on this one.
Answers anyone?
 Huh
