April 17, 2025, 08:33:15 pm
Ottawa Fiero Club Forum  |  General  |  Mods  |  Topic: 2.8 Aux. cooling fan mods « previous next »
Author Topic: 2.8 Aux. cooling fan mods  (Read 3129 times)
« on: May 12, 2003, 10:12:49 am »
Has anyone else tried this?  It's a modification which turns the auxiliary (rear) cooling fan on (independantly of the radiator fan) when the temperature in the engine compartment climbs past a preset limit.
It's the first in a small series of modifications I'm making in an effort to keep both the distributor and my temper a little cooler.  I'm not particularly impressed by my current 1:1 ratio for # of years driven to # of ignition modules replaced.   Angry
I installed it yesterday, but was unable to give it a final test run due to the presence of an angry orange exhaust manifold.  Apparently vacuum leak hunting season opened in my neighbourhood on Sunday. Wink
« Reply #1 on: May 12, 2003, 02:37:30 pm »
Just changed my pickup coil on Saturday. Funny it was OK when I parked it last winter. It's just got to be the heat that is cooking the electronics.
« Reply #2 on: May 13, 2003, 10:32:37 am »
I haven't killed a pickup coil yet, just 1½ modules.  The ½ module is a pretty red Holley Annihilator, which is just starting to get cranky as the heat builds up.
Assuming that the circuit modifications & thermoswitch location cycle the rear blower on/off appropriately, the next two things I have in mind are modifying the airflow path to include the distributor instead of just the coil, and mounting a small external heat sink on the underside of the distributor (below the ignition module).  I'm not certain how much it will help just yet, but some will be hopefully better than none. Undecided
...but those other mods won't come for a while yet.  I have a vacuum leak to hunt down and mercilessly execute first.
Swapped in my spare EGR tube last night, which alleviated the problem only just slightly.  The original tube feels like it has developed a crack two or three segments in from the end which connects to the EGR valve.  Assuming that the connecting ends of the old tube are serviceable, I may have a go at fitting them to a braided steel line of appropriate diameter as my "ultimate" EGR tube.  Wink
There be still a significant vacuum leak however--I can hear it.  A noticably out-of-place sucking noise, which fades & rises in concert with a wander in idle speed.  The front manifold still glows, but not quite as brightly as previously.  To be continued....
« Reply #3 on: May 20, 2003, 12:06:24 pm »
Got in to it on the weekend, and it looks like my "good" spare EGR tube is not so good after all.   Roll Eyes
Does anyone know where I might be able to purchase a length of braided steel line with an I.D. of roughly 9/16"?
I'd like to have a go at making my own tube, instead of feeding Jean's coffers by having one of The Fiero Store's braided tubes shipped up here.
« Last Edit: May 20, 2003, 12:17:21 pm by dguy » Logged
