April 12, 2025, 05:58:06 am
Project Work Logs
10
11
12
13
14
19
Topic: Thinking Northstar Conversion? (Read 121176 times)
Reply #165 on:
January 21, 2005, 01:07:34 pm »
You keep asking me that, but I really don't know because I still haven't taken it to the scales. I have calculated the weight to be around 2750 without driver, but I don't know for sure yet.
Reply #166 on:
January 21, 2005, 01:23:19 pm »
Quote from: Slammed Fiero on January 18, 2005, 08:31:23 pm
I have the Spec Aluminum Flywheel and the spec Stage 3 clutch. The swap is all done , just need the suspension on. I beleive I am the first to use the Spec flywheel on a northstar thus far... The flywheel is really nice , but pricey @ $400 + shipping Plus Brokerage fees. IT was close to $1000 for the Combo clutch and flywheel.
Sorry Aaron my last question was for him.
How is the Spec flywheel working out with the stage 3 clutch?
Reply #167 on:
January 21, 2005, 04:51:15 pm »
He'll know in March.
Reply #168 on:
January 24, 2005, 01:31:20 am »
I though he said he was driving it???
Reply #169 on:
January 24, 2005, 11:35:17 am »
The motor is running and he probably has the suspension together by now but, the weather here is nothing to be driving in yet.
Slammed Fiero
Reply #170 on:
January 24, 2005, 04:10:39 pm »
just finished the exhaust , all 2.5" mandrel bent tubing and Dynomax UltraFlow Bullet mufflers.. I got the coilovers this morning... Should be driving the car in 4 weeks.
JM
Maps
Reply #171 on:
February 17, 2005, 07:40:27 pm »
The following are some good maps to start with (Holley Commander 950).
I will be modifying / updating some of the maps so check for updates
First: Engine Paramiters
Last Edit: June 22, 2006, 07:04:32 pm by aaron88
Maps
Reply #172 on:
February 17, 2005, 07:42:05 pm »
Fuel Modifiers
Last Edit: June 22, 2006, 07:05:13 pm by aaron88
Maps
Reply #173 on:
February 17, 2005, 07:44:16 pm »
Acceleration Enrichment
Check for updates in the spring on the "Rate of change of MAP Sensor"
Last Edit: June 22, 2006, 07:05:39 pm by aaron88
Maps
Reply #174 on:
February 17, 2005, 07:45:52 pm »
Startup Enrichment vs. Engine Temperature
Last Edit: June 22, 2006, 07:06:04 pm by aaron88
Reply #175 on:
February 17, 2005, 07:53:36 pm »
Fuel Map
This map should be rich. The red indicates a pulsewidth that is a little too long. For best results, use a wideband O2 sensor to get the air-fuel ratio around 12.6:1 (O2 Lambda .8 +) in the upper region.
Last Edit: June 22, 2006, 07:06:28 pm by aaron88
Maps
Reply #176 on:
February 17, 2005, 07:56:54 pm »
Spark Map
This map should be fine with 91 octane fuel. I’ve been running up to 35° but I can’t recommend that to others until I have my knock sensor working and posted.
Last Edit: June 22, 2006, 07:07:13 pm by aaron88
Maps
Reply #177 on:
February 17, 2005, 07:59:12 pm »
Closed Loop Paramiters
I'm still working on "seconds between O2 compensation step changes". Trying to dial it in better.
Last Edit: June 22, 2006, 07:07:35 pm by aaron88
Maps
Reply #178 on:
February 17, 2005, 08:00:10 pm »
Idle Air Control
Last Edit: June 22, 2006, 07:08:10 pm by aaron88
Slammed Fiero
Reply #179 on:
February 19, 2005, 09:44:04 am »
this is beautiful , and perfect timing too. I will be drivingthe car for the first time monday.
All thats left is the shift cables and 1/2 of the exhaust.
Ohhhhh Baby!!!
thanks again!
10
11
12
13
14
19
Project Work Logs
