April 17, 2025, 09:42:40 pm
Pages: 1 ... 9 10 [11] 12 13 ... 19 Go Down Print
Author Topic: Thinking Northstar Conversion?  (Read 122143 times)
« Reply #150 on: October 04, 2004, 12:20:44 pm »
Congratulations on your choice and good luck with the work.  This thread is here to help people thinking about the northstar/manual conversion.
« Reply #151 on: October 04, 2004, 03:48:36 pm »
Aaron --- You get a weight on your machine yet?
« Last Edit: October 06, 2004, 07:25:45 am by GoFast88 » Logged
stroker
« Reply #152 on: October 05, 2004, 09:42:24 pm »
not yet i'm turning my 2.8 over to my other car this winter
witch will bee running next summer ,since this body has a lot less rust to it
so i have plenty of work to do this winter.
but i will next summer
marc.
« Reply #153 on: October 28, 2004, 04:17:39 pm »
Update on the Fiero coolant temperature gage mounting location.  I finally got around to checking it and I did mount it in the EGR system.
It’s on this page:
http://www.fierodrivers.com/forum/index.php?topic=765.105
northfiero
« Reply #154 on: October 29, 2004, 10:32:11 pm »
Instead of relocating it, you could always just tee off the TB coolant line, and run it through the egr passage....  Just a thought.
Rob
« Reply #155 on: December 04, 2004, 09:23:00 am »
Aaron88: Where did you get your Holley Commander 950? Im still researching options at the moment, and thinking maybe the n* little brother.
Thanks; Rob
« Reply #156 on: December 04, 2004, 01:29:56 pm »
I’m sure it’s in here somewhere, but CHRFab
www.chrfab.com
Expenseve though, something like $1300 with wiring harness and cables.
Slammed Fiero
« Reply #157 on: January 08, 2005, 07:52:34 pm »
Got mine running yesterday
http://www.supermotors.org/getfile/169312//northstar.wmv
right click , save as
Joe Fieroshop
« Reply #158 on: January 09, 2005, 10:11:49 am »
Hi Rob, are you looking for a V6 Shortstar? I have one or two kicking around that I'm not going to use anymore.
Joe
dfarrier
« Reply #159 on: January 17, 2005, 10:42:40 pm »
Aaron, what clutch did you use? I know you got the steel flywheel from CHRFab, but why did you not select a McLeod clutch that Alan also has available. I am sourcing the flywheel and clutch assembly for my 4.6/88GT and am undecided on the Spec stage II, Spec stage III or a McLeod from Alan. (I also bought the C950 from Alan)
« Reply #160 on: January 18, 2005, 12:06:36 pm »
I used a Ram HD clutch for one reason.  It is totally drivable.  It drives like a stock clutch but has a much harder clutch feel.  I wanted my car to be drivable in traffic.
Next time I change my clutch I’m going to try the Spec flywheel and stage 3K (now that they have one that’s streetable) clutch so that I can compare and report.
As far as I know Alan’s McLeod clutch is for the S10 (truck) transmission that he uses and I wasn’t sure it would work with the Getrag 282 transmission.  I didn’t want to gamble with it.  Maybe it will work, I didn’t even look into it only because I don’t know anything about McLeod.
Make sure, if you are going to get your flywheel from Alan that it’s the one for the Fiero and not the one for the S10.
Aaorn
Slammed Fiero
« Reply #161 on: January 18, 2005, 08:31:23 pm »
I have the Spec Aluminum Flywheel and the spec Stage 3 clutch. The swap is all done , just need the suspension on. I beleive I am the first to use the Spec flywheel on a northstar thus far... The flywheel is really nice , but pricey @ $400 + shipping Plus Brokerage fees. IT was close to $1000 for the Combo clutch and flywheel.
« Reply #162 on: January 21, 2005, 12:23:18 am »
Your driving it? So please do tell?Huh?
« Reply #163 on: January 21, 2005, 10:17:35 am »
I drove it all summer, it’s a wild ride.  Lots of power, handles well, it’s a good combination, but hard to explain.  I’ll have another video in the spring after the snow is gone.  I need to put the car on a serious diet though.  Going to try and get it down to 2400 lb.
« Reply #164 on: January 21, 2005, 12:18:46 pm »
What does it weight now?
Pages: 1 ... 9 10 [11] 12 13 ... 19 Go Up Print
