January 10, 2025, 04:16:11 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: Where can I get this??? « previous next »
Author Topic: Where can I get this???  (Read 1381 times)
maxx
« on: June 30, 2003, 03:29:49 am »
Floor drain plugs? These rusted on my car while in storage, and completely disintegrated. Funny thing is, the body is in mint shape around the drain holes, just minor surface rust that I grinded down with the drill. I talked to the dealership and they list only one part number for these: 15766910.
Problem is there are two sizes drain holes I see on my '84. Each side has 3 drain holes, two are the same size, but the third one is much bigger. Anyone knows the part numbers for these? And another thing, each drain hole was sealed over with a thin rubber sheet, where can I get something like this to reseal the new ones?
Thanks!
Marko
« Reply #1 on: June 30, 2003, 02:51:25 pm »
Use a sheet metal patch, rivets and caulking, Smiley
They were only used for draining the primer out of the chassis when it was dunked. No need for every day driving unless you normally drive your car in the river.. i hope not..
cheers!
« Last Edit: June 30, 2003, 03:43:31 pm by FieroDough » Logged
Boy-z
« Reply #2 on: June 30, 2003, 03:34:36 pm »
This is what I did with mine The same as Eric said and they came out better then the original plugs
