« Reply #16 on: July 14, 2003, 06:31:12 pm » |
I want to pull it out anyway and replace the lighting in it with my own version LEDS!!!! Ultra BRight ones . can you get 12V ulta bright blue lights? how much? pm me!
« Reply #17 on: July 14, 2003, 09:08:51 pm » |
Can always try plugging your 4cyl speedo into it to check as they are the same. I have a few extra gauge packages with good speedo's if you need one. Dan
« Reply #18 on: July 14, 2003, 09:20:20 pm » |
Eric, it is possible what you need is Let me do the math RED ULtra Brights are 3.6V you need 20mA so 12V-3.6V = 8.4 V=IR 8.4 = 0.02A * R R= 8.4/0.02 R = 420 Ohm Resistors. So get 420Ohms of resistance on the line, then put the LED's in. If the voltage on the LEDs are different, change the equation to match. If you need anymore information, ask away
« Reply #21 on: July 15, 2003, 04:50:53 pm » |
But but but, I need to know were to get the LEDS were can i get really bright blue leds? Cheers! Eric
« Reply #23 on: July 15, 2003, 06:50:54 pm » |
