December 27, 2024, 09:12:19 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: My new car -status « previous next »
Pages: 1 [2] Go Down Print
Author Topic: My new car -status  (Read 8520 times)
JetJumper
Jetjumper
« Reply #15 on: July 14, 2003, 04:53:35 pm »
I want to pull it out anyway and replace the lighting in it with my own version  Smiley  LEDS!!!! Ultra BRight ones  .
JetTech
www.jetjumper.ca
« Reply #16 on: July 14, 2003, 06:31:12 pm »
can you get 12V ulta bright blue lights? how much? pm me! Cheesy
« Reply #17 on: July 14, 2003, 09:08:51 pm »
Can always try plugging your 4cyl speedo into it to check as they are the same. I have a few extra gauge packages with good speedo's if you need one. Dan
JetJumper
Jetjumper
« Reply #18 on: July 14, 2003, 09:20:20 pm »
Eric, it is possible what you need is Let me do the math
RED ULtra Brights are 3.6V you need 20mA  so
12V-3.6V = 8.4
V=IR
8.4 = 0.02A * R
R= 8.4/0.02
R = 420 Ohm Resistors.
So get 420Ohms of resistance on the line, then put the LED's in.  If the voltage on the LEDs are different, change the equation to match.
If you need anymore information, ask away Tongue
JetTech
www.jetjumper.ca
« Reply #19 on: July 15, 2003, 07:13:00 am »
Hey Chris,
12V-3.6V = 8.4
V=IR
8.4 = 0.02A * R
R= 8.4/0.02
If you want to prolong the life of your LEDs, you might consider recalculating for a supply voltage of 14.5, not 12.
Unless of course your charging system needs work too.   Grin Grin Grin
JetJumper
Jetjumper
« Reply #20 on: July 15, 2003, 03:29:43 pm »
shit,  thats true...lol but then they are not as bright Sad  LOL!!! but last longer I suppose
not unless you put voltage regulators in there...not that you want to buy those things Tongue
JetTech
www.jetjumper.ca
« Reply #21 on: July 15, 2003, 04:50:53 pm »
But but but, I need to know were to get the LEDS Tongue
were can i get really bright blue leds?
Cheers!
JetJumper
Jetjumper
« Reply #22 on: July 15, 2003, 05:15:09 pm »
blue ones eh?  Um...you they are not that cheap, but you can order packages of like 5
Pack of 4 x 5mm blue LED
Voltage norm 3.0V - max 3.3V
Brightness 3000 - 4000 mcd
Usage
100 Ohm resistor for 5volt supply
470 Ohm resistor for 12volt supply
those packages are $2.50 each (USD)
http://www.coolerguys.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=001&Product_Code=840556011279&Category_Code=CS-LIGHT
Go there for more info.
Copying my Idea Tongue
JetTech
www.jetjumper.ca
JetJumper
Jetjumper
« Reply #23 on: July 15, 2003, 06:50:54 pm »
People on 56k are going to hate me for this but Tongue
Here are the pics you have been waiting for
JetTech
www.jetjumper.ca
« Reply #24 on: July 16, 2003, 10:24:35 am »
Chris you bastard I can't even get a 56k connection from home.  I do a happy dance when ever I see 31.2k!  There's a reason why I do most of my forum-stomping while at work.  Shhhh...
I like the dual purpose bucket/axle stand in the first photo!   Grin Grin Grin
Assuming that you don't mind sharing, what is your $150 special up to now?  We basically have the same car; mine sans-sunroof, but it makes up for that by having three pedals instead of your lowly two.  Wink
JetJumper
Jetjumper
« Reply #25 on: July 16, 2003, 05:28:13 pm »
lol....So far it is up to $160 lol....Basically brake line replacement cost.  The bucket is for the brake fluid, but nothing was coming out so I just left it there.
I have to get this console tested somehow, anyone got a start instrument panel, I just want to plug it in and test it out.
JetTech
www.jetjumper.ca
« Reply #26 on: July 17, 2003, 08:53:17 am »
If you like, bring it out to my place on the weekend, and we can pop mine out and plug yours in to give it a shot.
Heck the front end of the car is already partially disassembled; I see no reason to disassemble part of the interior too.  Wink
JetJumper
Jetjumper
« Reply #27 on: July 27, 2003, 10:29:33 pm »
Well, its in the shop getting work done to it and having a thorough inspection.  Hopefully when its out it is certified Smiley
JetTech
www.jetjumper.ca
Pages: 1 [2] Go Up Print
