April 17, 2025, 05:42:10 pm
Ottawa Fiero Club Forum  |  Buy/Sell/Trade  |  Parts  |  Topic: Last of the v-6 stash F/S « previous next »
Author Topic: Last of the v-6 stash F/S  (Read 3014 times)
« on: July 09, 2003, 04:26:09 pm »
Okay. I'm down to a couple of bigger bits:
**CTC exhaust system 1 piece muffler and pipes**
**Clutch Kit 4 speed (friction and pressure plates and TO bearing**
**Clutch kit  as above TO bearing different so I assume its a 5 speed**
« Reply #1 on: July 10, 2003, 08:07:44 am »
What's the 4spd clutch kit worth to you?  Mine's starting to chatter...   Sad
« Reply #2 on: July 10, 2003, 09:07:34 am »
Don, I'd like around 150 but make an offer.  It's from Canadian Tire but PBJ says it's made by the OEM GM supplier and identical to those he uses at the dealer. He uses them on his cars.
Cash or labour accepted.  Still need to drop the cradle and gas tank  Roll Eyes
« Last Edit: July 10, 2003, 09:09:20 am by FieroBUZZ » Logged
« Reply #3 on: July 11, 2003, 08:35:48 am »
$150 works for me.  I'd offer up some labour, but with the new kid arriving tonight I suspect that I'll have to stick close to home for the next little while.   Undecided
Are you swapping the gas tank from a donor into Frankenfiero?  If you want to take your time with it (pulling from the donor), I have a leak-less tank in my stash, complete with sending unit and pump that you can have on trade until you get to pulling the other tank.  Heck there may even be some 18-month-old gas still in it.   Grin
« Reply #4 on: July 11, 2003, 10:43:55 am »
Don, I have to replace my fuel pump.  The tank was out last summer (fuel pump  Roll Eyes ) so I don't expect a big problem on the re and re.  Although if you have a set of 4 cyl fuel lines in your pile LMK.
I am around most days so just call when you'll be home and I'll run over with the clutch.
256-1018
