January 10, 2025, 10:53:04 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: Holly water time « previous next »
Author Topic: Holly water time  (Read 1267 times)
Rebel
« on: August 09, 2003, 09:54:00 am »
Aim working on an 84 2m4
The problem aim having is a pulse like miss when I bring up my idle around 2000 rpm the miss/ like surge is also present while peddle pressure is light seem to go away while engine is under load like accelerating
I have check all sensor they seem to all be ok had a mechanic run is diagnostic computer on it 3 hours later still no result
Next step is holy water I think it F;;;;;;;; Poses
If any one as had similar problem in found a solution please let me no
All feedback will be warmly welcome
Thank you
Rebel
fierorebel@sympatico.ca
 Cool
« Last Edit: August 09, 2003, 09:58:56 am by Rebel » Logged
« Reply #1 on: August 09, 2003, 12:38:23 pm »
I have had that, but that was with the old engine which is now DEAD.  I couldn't tell you what was causing it, but I was sure it was electrical
« Reply #2 on: August 10, 2003, 09:45:35 am »
Rebel,
Does this happen when she's hot, cold, or all the time?
I've heard more than one complaint of un-curable rough running/hesitation/you name it when the Iron Duke is cold, which disappears after she warms up.  I haven't seen any concrete evidence to support it, but my theory is that the static values which the ECM uses while in open-loop are less than ideal for a moderately worn engine.  Once the O2 sensor warms up and the ECM swithes to closed loop, it starts "thinking" and the hesitation & whatnot goes away.
