January 11, 2025, 04:02:19 pm
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: slicks & boost = « previous next »
Author Topic: slicks & boost =  (Read 1610 times)
« on: August 23, 2003, 12:24:53 pm »
Important note to 3800SC guys do not try using slicks when racing. Tried it, launched beautifully pulled both front tires out of hole and then lifted both again going into second but tore my passenger's side CV joint apart going into third.
In total one axle shaft, one rear hub destroyed other than that one valuable lesson learned. Need stronger axle shafts before trying again. Dan
« Reply #1 on: August 24, 2003, 03:46:28 pm »
hi Dan
SOUNDS impressive.  Always does when people are going so fast they break........!!!!
There is an axle place up here that has a pretty good rep.  There is also one that has a less than great rep, so if you are looking for sources etc maybe I can pass that along.
PM me if you are looking for leads, etc.
